Some of you may remember that I have a problem with a strong petrol smell coming from my 02 Adv whenever its parked up warm (especially in the confined space of my garage).
There are no apparent leaks, and all fuel/breather lines/’o’ rings/filter have been replaced. The smell has been 100% traced to the ‘expansion’ breather. So I figured the petrol is getting warmed up by the hot engine and the breather working properly. So nothing to fix, then.
The smell of petrol was cured by connecting the breather to a length of garden hose (suitably affixed around my garage walls, which then exits through the outside door), every time I park up the bike.
This has been working fine for nearly a year now. But last night one of the garden hose connectors came loose and I was reminded of the appalling amount of fumes my breather kicks out.
Something aint right.
So I was sat in the quiet of the garage having a ‘thinky’ about it.
Every 10 to 15 seconds there was a gurgling in my tank. Air is coming in and bubbling up.
Now this has me confused. How can air get in, without petrol leaking out? And where is it coming from?
The heat of the engine is causing the pressure – once cool there’s no smell.
It must be from a source of air with enough pressure to push past gallons of petrol (infact the fuller the tank the less the smell – seems logical).
So it can’t be from outside the tank.
Still bubbles with filler open, so isn’t being sucked in.
Must be from inside the fuel lines? Is there any air in there? And where from?
Any ideas?
It appears I’ve got a leak that’s working in reverse.
if so can I have a leak like that too
