RHS final drive seal - top up fluid?
Demongroover
Derby
Just a quick question.
I've just replaced the RHS shaft seal on the final drive.
Prior to replacement there had been abouth a centimetre of dampness on the casing around the seal, no drips or puddles.
As there was so little 'apparent' fluid loss, would you drain and replace the fluid?
(As there's no way to determine the level within, due to bad design and no fill-to-level hole).
Scrub that, the f**king things pissed gear oil out all over my tyre and rear brake. Seems replacing the seal's made it worse! :blast
On with the 4th final drive unit, order another seal for this one! :mad:
