RID…engine oil temperature, R1100GS
cxp
Aberdeenshire
my engine oil temperature indicator keeps going blank.
the bike is a 1995 R1100GS
every time I start riding, the temperature indicator seems to work as expected, gets up to 3 or 4 bars, but normally after 5 to 10 minutes all the bars disappear
sometimes they come back on, but never for long
anyone know what the problem is and how to fix it?
If it's like the fuel gauge issue it will be corrosion in a connector... 'fraid I dunno which one though... :nenau
Someone should be along to make a sarcastic remark shortly.. then a bit later a helpful reply ;)
Try the connector where the rid joins the main harness. When the temp indicator played up on mine this was the culprit. It could also be a connector to the oil temp sensor.
Sarcasm is the lowest form of wit; irony is much better, but pathos is a real no-no, especially with the dire financial position of Greece.
