Thanks for that link; I hadn't appreciated that Pragmasis was effectively changing hands....Shame they didn’t review the Double Doofer.
An excellent and solid heavy duty bit of kits which, unloke most can easily be repositioned after fixing.
LINK
Dunno if they are or not....but installing one would be a whole load more work/hassle than the reviewed ones.View attachment 390372
Strange they didn’t not include this type. Surely these are more secure.
Not when one is laying a new garage base as I was when I fit mine. Obviously I tripped over it at least twice before the garage was builtDunno if they are or not....but installing one would be a whole load more work/hassle than the reviewed ones.
Mine was locked to one and the chain was cut in a short time with an angle grinder.View attachment 390372
The chain is usually the quickest thing to cut through, so no surprises there. Few defences bar grinder resistant locks will prevent determined thieves, but yes, if ultimate ground anchor security is wanted then one of the grinder resistant anchors are better BUT of no use whatsoever if they can cut through your chain. A grinder resistant anchor, either the type using a hinged arm or one like the one shown below, offers the best resistance in combination with a grinder resistant D lock but cost a lot of money:Mine was locked to one and the chain was cut in a short time with an angle grinder.
That's the one I have which was at the time I bought it was rated as the very bestI've added to my ground anchor with another, and looking at the above, wanted something allowing larger diameter chains but more compact in size. A bit of research pointed me to the Pragmassis Torc.
Torc Mega Ground Anchor
The Torc Mega is a substantial, fully forged ground anchor with a 22mm shackle. Supplied with a choice of fitting kits for walls, floors, vans and bike sheds.securityforbikes.com
Bought one and waiting for it to arrive but the specs seem really decent. Allows for chains up to 25mm link size, (the larger torc Maxi will take at least two 22mm chains) loop head needs two cuts through the hardened steel loop, using a massive 22mm shank, to defeat it. Motorcycle Diamond rated too. Really keenly priced, it's another winner from Pragmassis.
Tested: Pragmasis Torc ground anchor review (Maxi and Mega)
The best motorcycle chain and lock is no use if you don’t have the best ground anchor – full destruction test review of the Pragmasis Torc Maxi and Megawww.bennetts.co.uk
Yes, mine is going up against a wall.Suggestion, you might want to put the ground anchor in an awkward place, perhaps between the bike and your wall. It makes getting a grinder in there much harder.
A bit more fiddly to lock though.
BTW The Pragmasis Double Doofer can be relocated easily.
The outer ‘skin’ covers the bolt heads and can lift off once you take the chain away. The Double Doofer bolts are then accessible, but only when unlocked.
(The anchors tested all have the bolt heads exposed. A ball bearing prevents removal, but also relocation.)
