riders lower pegs for bmw 1150 gsa recommendations
bim3330
bridgend
hi guys
i hace a 2005 1150 gs adventure seat can,t be lowered and i,m finding the standard pegs to high i,m cramped up uncomfortable
can any bodt recommened a good after market lower riders pegs please
rob
These are the best I believe.
I have Migsel ones but I wouldn't really recommend them as they shorten the distance from the peg to to gear lever and brake too much.
+1 for the Wunderlich set which are brilliant and include everything including lowering of the gear and brake levers. I’ve had the set fitted since I owned the bike (2003).
Be aware that you will catch either your boot or the pegs on tight bends.
If the pegs are too high, why would you even think about lowering the seat..?
I’d suggest starting off by sitting on top of something to see if that makes you more comfortable? Then you’ll know how to proceed at least cost.
- If you’re comfortable and can stop confidently, then you can just get by with a raised seatpad
- and possibly a longer paralever arm to lower the rear if it’s marginal
- otherwise you need spend £££ for something more ‘engineered’
i,m not thinking of lowering the seat, i,m 6 ft 1 in tall the seat can,t be moved and the pegs are to high i,m cramped so need to lower the pegs
There's also these
hi guys
rob
Back to your first post, where you mentioned lowering not being possible… I hope the rest of my post was still helpful 😊
I have Pan European pegs on mine. They went slightly forward and down by about an inch. You just need a bit of angle aluminium on each side trimmed to shape.
Winderlich the best,have had them on for many miles but if you are’earoling whatch out for grounding recommend these first rate product.
i bought a set of SW MOTECH lower pegs for my bmw 1150 gsa 2005 can i ask you guys that have lower rider pegs fitted is there enough adjustment on that gear short rod to lower the lever enough for you
rob
hi dave
i see you have said you have the wunderlich rider pegs fitted i see they drop the pegs quite a bit to can i ask did you have any issues lowering the gear lever as the rod is short and it doesn,t look like to lowers it enough were you ok with it
cheers rob
hi dave
cheers rob
I think I can answer that….
If the rod in the kit is short, then it screws into the end of the existing rod to lengthen it.
Interested in doing this, what year Pan foot pegs or do you have a picture please ? Thanks 👍🏻😊
Well yes, but I’ve since moved on to the far superior Fastway Footpegs.
With a much bigger footprint and spikey studs I find them a lot more comfortable on longer runs.
My feet don’t slip on the pegs either now.
I have some MV ones…… somewhere🤷
Woderlich no1, had them on for 90k and been brilliant, tend to touch on fast corner. (Don’t help with spelling though).
