Road tech zumo 660 question
oly
Cockermouth Cumbria
Got a road tech sat nav which is the harley davidson zumo 660.
Only problem is the harley logo that comes on screen when youmpower up.
Can this be wiped off as can the list of harley dealers?
You can but try. Go into the Picture Viewer and check the "Set as default splash screen" box beside a picture. If that then appears when you boot up the Zumo, then you've succeeded; although, if they've programed the Road Tech the same way that they've done the Navigator IV, I suspect you'll be out of luck.
I think the same is true of the dealer waypoints.....:nenau
Give up, just buy a harley!
Change the splash screen. I use BMW Motorcycles screen. The Harley screen is there still, but for a split second. and like the Harley dealers, they are embedded. The Zumo forum says they have to stay.
