Roadking special rear mudguard grommet
Flipfly
Stoke on Trent
Hi gents. Just fitted a charging lead to the RKS (turns out it was already fitted with an optimate one :blast
Anyway, I took the seat off and it was filthy under there because there is a bloody hole in the fender with no grommet in it, so shit is coming straight off the tyre into the underseat area.
I can’t find any reference to this hole being plugged with anything :nenau doesn’t show on the microfiche but wondered if anyone else with an RKS can pop their seat off and take a quick pic for me please.
Thanks in advance :thumb
Anyway, I took the seat off and it was filthy under there because there is a bloody hole in the fender with no grommet in it, so shit is coming straight off the tyre into the underwear area.
:D:D Has someone hacked your life?
Lovin it matey, still trying to find a silk stars n stripes bandana and currently perfecting how to say Y’aaaaaaallll. I’ve got noisy pipes too (apparently they ‘save lives’).
It’s the hole for the single seat rear mounting point - it should have a rubber grommet in it...
I’ll have a look at mine tomorrow if it helps?
As you now know an optimate lead is hidden under the left hand side cover. :blast
Just had a look at the Jersey HD Microfiche... seems to just be a hole!!
My million year old Glide had a. Rubber grommet - must be cost cutting!!
Stick a square of Gorilla Tape over the hole - job done!
No it aint,just measure the hole and get 1 off e/bay or just put tape over it,cut it too size though other wise you will see it from the o/s of the bike.
If I can remember it's for the wiring going to the rear light/indicators.
Will take my seat off in the morning for a look see.
Just wondering if it was missing a genuine Harley grommet, but it looks like it’s not the case. A solution will be found, might need to buy a welder, a plasma cutter, two strips of gaffa tape, a flat plate of stainless, three sausages and a case of frogs.
Just push a frog into the hole... that will sort it.....
Rivet....
I’ve got two....
Sadly both employed keeping the water in...
Big hole here. :thumb2
Cleaned up in 30 seconds. :thumb2
Is that under the seat? Why didn’t they paint the hidden parts of the bike, rather than just leave it in primer? Shoddy work if you ask me...
