Sold Roadlok XRA Eurosport - fittings for R125O and bikes with Radial calipers
GSite
Nr Sleaford, Lincolnshire, UK
Here is a used Roadlok XRA Eurosport
This is designed to fit onto a right side radial caliper which has mounting bolts 100mm apart.
The supplied bolts and spacers replace the OEM caliper bolts.
The replacement bolts are longer so that with the spacer the length into the caliper housing is as per the OEM bolts.
This was used on my R1250GS with the supplied fittings, but will go on quite a few modern BMW with the same Brembo brakes such as RS, RT, XR, F900 in addition to other bikes using the correct length bolts and spacers.
I had the same one on my later LC 1200GS and RT so please check on the Rodlok website for suitability as per the following link:
https://roadlokuk.co.uk/which-roadl...cts_filtering=1&wpf_filter_tax_block_logic=or
When ordering direct from Rodlok you get the correct spacers and bolts for your bike and these are for the BMWs as stated, but if your bike needs different ones please get in touch and if I have the correct sizes I will include those.
Included:
Two keys
Brake bolt - inserted into the housing to lock disc.
Dust cap barrell - replaces brake bolt when not locked to prevent grime getting into the housing.
Caliper bolts and spacers to enable fitment as above.
No corrosion, all parts operate smoothly.
New these are £209 plus postage.
Asking a very reasonable £100 posted to a UK address.
Thanks for looking.
Without hijacking this thread and hopefully the sale will go through, but can I just ask who has had experience of these and do they truly work?
Youtube reviews especially Bennets bike social have tested and this works very well compared to alternatives.
Locks wheel so it does not move a fraction, meaning bike cannot be takwn off centre stand with lock in place.
More resistant to grinder attacks than many.
I’ve seen the YouTube videos and have been considering one for awhile, but like many things wanted some form of human confirmation👍🏻
They're brilliant. Once set, you'd need 2 or more cuts to remove, and take up very little space.
Top tip, better set when bike is on the main stand, much easier to remove the pin.
