Rocker arm/shaft
pieter.oneill
Staffordshire
Changing over my heads after getting some new ones back fromnthe head shop with valves re seated. Anyway thought id change the gubbins over this bank holiday weekend. While transfering cams and rockers checking push rods and other bits i noticed the rocker arm and shaft one side is tight cleaned it, oiled it and its still no good, swapped the shafts round an they are ok, so it appears to be the arm tube itself that has some how distorted slightly.
Dont spose anyone has old one kicking around in the midlands area i could come and buy to crack on with? If noy plenty on the net but just thought id ask. Cheers all
And on futher inspections i need new followers as well 🤣 by the end of it this bike will be like triggers broom haha
I can't remember where this started .. was it an engine failure...?
No bike was running good enough, but my heads were nackered (threads gone on cover screw, exhaust studs rusted as hell) so i got some low milage heads from germany, then had cylinder head man up north re do valves and guides.
Im now stripping whats on bike cams and rockers were being swapped to the new heads and thats where im at now. Bike had done 120k so i thought why not get in there and get id done.
Im.guessing the other side is going to need the same, cam lobe is a bit rough on the one where the follower had worn so need that too.
