Is it possible to shim the rocker shaft without removing the clinder head.
What am thinking is, if I remove the two outer clinder head nuts will it warp the head. I know you suppose to remove the head nuts in a crisscross pattern???
So if a wanted to shim both rocker shafts there would be only two(top/bottom) head nuts holding the head in place. Would this warp the head????:
