Further to my search for the source of my PPP (pesky petrol pong):
There are two breather/overflows from the tank. One from the fill nozzle (overfill/bungling hands
), and the other from the 'rollover valve' (situated inside the tank below the filler).
When the air in the tank expands (parked up, hot engine etc) which does it use to ventilate?
My guess is it's the rollover valve breather.
I have now traced my ppp to this breather. When parked in my garage after a run the petrol fumes can be seen blowing out of it (very hot engine, only a couple of litres in tank). Temporarily blocking this breather 'seemed' to reduce ppp (after ventilating garage), but there was a hell of a pressure build up after 10 mins or so.
My initial thought was that petrol must be getting into this breather at the connection in the access plate (although I checked this yesterday), but now I'm wondering if something might be wrong with my 'rollover valve'. (Pipes are all connected)
Can someone kindly explain what the rollover valve does, and how it does it? And does mine sound knackered?
Cheers......
Note: I haven't had to test the valve in a 'rollover' situation........yet
Cheers......
