Rough engine
  • Thread starter Thread starter Bikes on World Tour
Bikes on World Tour
High, we are on world tour and the engine of my R1100GS is not running as smooth as before after service.
I had the clutch replaced in Bangkok and the engine is running quite rough, not as smooth as some 10 k before.
I am wondering wether there is a mis-balance between the two cylinders. Or maybe a plugged injection needle.
The idle has become a bit rough, but it gets a bit worse when I starts riding. At 1500-2000 rpm the engine kinda shakes a bit, under normal riding conditions the engine runs rough with a some vibration. Power is still OK.
Any idea about the reason: cables, injection needles, spark plugs, magnetic valves, slight mis-synchro?
Thanks in advance.
Many greetings from the Cameron Highlands in Malaysia Kai
www.bikesonworldtour.de
Sorry mate am a BAKER.
But give it 10 minutes and I`m sure somebody will be along, theres loads of folks that are very knowagable.
Cheers,
Eat bread stay slim.
Bit difficult to diagnose at a distance, but sounds like throttle bodies out of balance. Suggest a visit to another dealer to check. Sorry I can't be of more help.
check the cables at the engine end are seated properly, common fault. Hopefully its as simple as that
Thanks in advance.
Try slackening off the r/h throttle cable a little - possibilty the cable might be allowing it to open too early. Could also possibly be running weak .If your not near a dealer try adjusting co pot if you have one - access hole underneath rear mudguard on r/h side of bike.Lookin at it from underneath try turnin the screw a couple of turns anti clockwise. Have they disconnectd any of the sensors accidently with the ignition switched on? It will log a fault in the engine management computer if so.
