Route transfer between 2 Zumo 660's....can this be done via BT & if so...how?
Bounce
Sandwich Bay, Kent
I'd like to send some routes to a mates 660 via BT......can this be done, and if so can someone share the transfer process please.
Thx :D
Email routes or share the SD card to get them onto the device. BT is only for phone & headset connection.
Although BT route transfer is possible (and very easy) with the Nav V
Could you temporarily swap SD cards and transfer the routes that way?
Thinking aloud...where does the 660 import routes to? If it's the unit and not the SD card ( which you obviously need to happen once swapped) just enough mail him your gpx. If it unwraps it on the SD card,you won't be any better off..
Sent from my SM-G920F using Tapatalk
Import route from SD card to device & remove card. Far easier though just to email route & open it in BaseCamp & transfer to different device or installed SD card
