I updated the firmware on our DG834GT last week. Ever since then the broadband (BT Broadband) connection speed (via ethernet) has dropped to 2 to 2.5Mb/s. The router has stayed up for five days now but the PPoA connection is dropping out a couple of times a day. Prior to the firmware update I saved the router settings and have reloaded them, so as far as I can tell everything should be the same....
On the router the connection speed is shown as 5.888Mb/s, noise at a consistent 6.5 - 7db, attenuation at 41db, line profile is 5Mb/s.
A speed test via wireless on the laptop gives 5.5Mb/s. Plug an ethernet cable straight in to the router and the same test drops down to 2 to 2.5Mb/s.
We're running a gigabit network using fixed IP's. All DNS settings set to google DNS Servers. I changed the switch from a D Link managed one to a HP unmanaged one a couple of months ago but this is only a recent problem. No difference if I disconnect everything from the switch.
Tried altering MTU settings on the router and on the NIC's - 1500, 1472, 1458. No difference.
Sorry for the long winded post. I'm normally OK with this stuff but this has me stumped. I'm trying another router later to see if that helps, but if anyone has any ideas then please post.
