Rox Risers
Here you go.
As you can tell, I put a bit of tape where the cable 'hits' the riser. I doesn't really rub against it much, just done as a precaution.
Cheers for the pics, got a set of anti-vibe ones on order do you reckon its better and comfy fitting them forward?
Im not as tall at 6"3 so just wanting your thoughts.
Don't know anything about the anti-vibe ones.. Look nice.
Just experiment with the position I would say. Everybody has their own preference. They are very easy to adjust so I'm sure you'll find a comfortable position.
Good luck.
Sent from my GT-I9305 using Tapatalk
Got the anti-vibe ones fitted tonight, whats the easiest way to remove the throttle cable so i can route it under the bars as its too tight on full lock.
