Rukka gloves & heated grips, advice required
paganman
Kirkbymoorside
I'm after some decent autumn / winter gloves, my current ones make my hands sweat which then gets cold due to wind chill n my hands get cold.
I don't want big numb gloves and have drawn a short list of 3 rukka gloves, the Pluto, Atlas or Mars. They seem similar specs, n similar prices.
Can anyone advice on suitability and how good they are?
I ride all year and am on the road at 0500 some days.
Thanks for any advice.
Have you considered using muffs? They don't look great (if that matters to you) but they are probably the best answer for year round riding. I use them with heated grips and just wear light weight gloves. No need to worry about waterproof gloves either.
Just refitted my muffs as the temps have suddenly dropped, which means i can wear much thinner gloves and actually feel the heated grips without sweaty paws. :thumb2
Muffs!
I have Rukka gloves (GTX Xtrafit), predecessors to the Apollo, and heated grips. They're a good three season glove and in winter I fit muffs. Not the greatest looking accessory for your bike but one of the best winter mods you could do. They allow you to wear a thinner and, maybe, more comfortable glove and still have toasty hands.
Val of this parish sells them HERE.
HTH
Helmet
Summer gloves, muffs and heated grips. Period.
Muffs give a 10 degree Celsius advantage.
Winter gloves are like wearing condoms - takes all the feeling away. Muffs do take a bit of getting used to though but all is good.
+1 windychuffer,have rukka gloves but you can't beat the muff (no pun intended):JB well she'll hate you for it
Consider the Apollo glove....an excellent glove summer and winter, especially with heated grips.
:thumb2
Rukka Argosaurus + muffs in winter. Can't go wrong once you get used to playing with the controls 'blind'.
I have just bought some Rukka Pluto gloves for the winter and they are bedding in well. Bit of a loss of feel but they are softening up with use.
Got a great price from BikerLand and they were here in two days. Went for a size larger than normal to allow for Rukka's tight sizing and to give my fingers a bit of room. Work great with heated grips so far.
I might consider muffs if these don't do the job but my commute is only 15 miles so hope to get away with just the Rukkas and heated grips.
Tom
tommac,
trust me,when its pissing from the heavens and freezing cold,your hands are toasty warm & bone dry with the muffs.:D
Sorry, first post but had to butt in! Heated gloves are the way forward. I have some knackered nerves in my left arm and need to see my clutch hand. Muffs won't cut it! Exo heated gloves save me every winter, along with the V-Strom handguards... :cool:
Sent from my Desire HD using Tapatalk 2
if you have muffs and heated grips why bother with heated gloves??unless you haven't got heated grips i can see your point.If i had problems with my arm i would fit a quick shifter and save myself the hassle.:thumb2
On the flipside, I too have knackered nerves in my fingers ,to accompany my Raynauds Disease, and I have found that heated gloves don't cut it, but muffs are the way to go. :beerjug:
A lot of sense on this thread, let me just a point to consider when thinking of what set up you'll adopt..
Heated grips and GoreTex/Dryway etc don't mix.
Nicely explained here
and elsewhere on this f'rum an all
and just my £0.02 if I may....
Sizing of gloves is key - must have ample room, (particularly in the finger boxes) as if they are to snug/tight (even a little bit) circulation is compromised leading to numbness/coldness /hand fatigue etc. I suffer from Reynaulds and the biggest difference to me was to buy bigger gloves.
Of course, Muffs solve this issue completely....
I started a thread some time ago here related to my numb finger problems - concluded eventually that my problem was my Raynaud's Syndrome not being triggered by cold fingers but by my body being cold. Although I can sense my fingers are cold, if I keep my body quite warm the blood continues to circulate fine through my fingers. The difficulty is that the sense of cold hands is usually stronger than the sense of a cold body and piling on thicker gloves seems the obvious thing to do - but if I put plenty of extra layers on I can ride fine in much thinner gloves! Now planning to invest in a good heated jacket for this winter :thumb2
I use the warm'nsafe heated gloves and jacket.
Using the separate dual remote controller means that they can both run at different temperature settings.
Not cheap but very comfortable.
Hi Bobbin-man
Like you the cold body thing also can trigger off the Raynaud's for me - so I did buy a Gebring heated jacket about 4 yeares ago, without doubt the single best piece of equipment I have ever bought. It can genuinely turn you from a fair weather biker to a year round biker no problem. In fact sometimes its too hot (even in minus temperatures) and I have to turn it down/off for a bit! :D
I wish I had bought one years earlier, get really annoyed with myself when I think of all the times I didn't go out for a ride cos it was to cold:blast
Get one you wont regret ti!
:topic glad you brought that up solidstate100,I've been looking into getting heated clothing & haven't come across many folk/reviews on it.Was looking at gerbing & a few others.so you rate it pretty high then?:eek:
