Can you get channel 5 on that?
Sent from my iPad using Tapatalk Pro
No, you need the 32 inch screen for that. Could adversely affect forward vision though!
If it is the Brodit mount they don't fair well long term with water and stop charging. If water gets in the USB port it won't charge. The screen also hates rain and it will go hay wire confusing water droplets with touch.
I use mine for greenlaning so I have a large clear map in eyeline that's the only good thing about it.
The tablet is a samsung activ tab T365 I think.I meant to ask you, what tablet & mount are you using ?
Have you used a wunderlinq with your mount ??Samsung galaxy Active mounted on a R1200gs LC not tested it yet but looking good so far.
I did , and TBH , gained nothing , other than being able to use the duplicated Nav optionsHave you used a wunderlinq with your mount ??
