on my bike I fabricated a bracket to go on the right-hand side of the bike, and then used a NN accessory socket, as it came with a fuse already fitted just going to put mine in the tank bag as it is not water prof
What's a "light socket"![]()
a light socket would be anything from 4mm to 13mm.
anything bigger could be described as a heavy socket.
it's o.k - no thanks needed.
here's one i prepared earlier....
Does Nippy do a 12v adapter for one of those![]()
possibly a 1/4" to 3/8" to 1/2" adaptor - voltage unknown.![]()
...the wire come out under the front of my seat and goes in the my tank bag i have put the socket in a water proof bag as the socket is one of the metal one and not the ones covered in plastic plus if its in the bag it should be fine
i have just wired up my lighter socket on to the bikes accessory socket the way there wire were fixed on was bad so i put a new socket on and it works the wire come out under the front of my seat and goes in the my tank bag i have put the socket in a water proof bag as the socket is one of the metal one and not the ones covered in plastic plus if its in the bag it should be fine and when i get some money i will get a sat nav clamp for my bars
Just bought a Centech fuse box for my PD -where have people fitted them ?
Fitted mine on the back mudguard after using "potting" on the underside of the PCB.
I then binned it after 6 months.
I the terminals are cheap junk and 2 of them failed.
I think a Power Plate from the US would be a much better solution. It uses a relay. I had one on my Valk and it worked very well.
Just my 2d
John
