Scala G4....what buttons do I press to pair with a non cardo intercom
Bounce
Sandwich Bay, Kent
I've forgotten which button/s I need to press on the Scala G4 unit in order to pair with a non cardo intercom unit (happens to be an interphone).
Can someone with this info please let me know....thx :thumb2
I don't think the G4 pairs with non-scala units
The other might pair with the G4, in which case - press the centre button on top edge until you get the double-flash
Al
I think its only the Packtalk that will communicate with non Cardo units - thats what I was advised to purchase to communicate with two really old Q2's
PS its a fantastic piece of kit once you understand the instructions
I've managed to pair the G4 with an interphone F5MC before, but can't recall how I did it!!!
To pair with a phone you need to press the top centre button fir about 6 seconds until it flashes red and blue then find it using Bluetooth and the pass code us 0000
I've done this with ease :D, so no issue there....just need to know the pairing sequence with another non cardo intercom
FWIW - managed to successfully pair the G4 with a new interphone tour by doing this:-
> Turned the interphone on & pressed the BT button to initiate pairing
> Turned the G4 on and press/held the volume up button until it flashes blue/red rapidly
> The 2 will then connect & the G4 light flashes blue slowly
Then, when you've turned the devices off to re-charge & then switch back on, they auto pair :D
