boxer Like Newton - only stupid UKGSer Subscriber Joined May 1, 2002 Messages 2,485 Reaction score 223 Location Clinging to reality by a finger tip. Dec 20, 2005 #1 How do you tell if a scart cable is fully wired? Is it just a matter of testing for continuity between pins at either end? Thanks. Russ.
ianf Complete Member UKGSer Subscriber Joined Feb 14, 2003 Messages 2,323 Reaction score 13 Location Ashford, Middlesex Dec 20, 2005 #2 Nope, cos there's a crossover on a few pins. Fully wired ones tend to be thicker than the cheap composite only type, but you cant really tell without opening up the plugs or buzzing it. google threw up this as a diagram to use if you do want to buzz it. you need the 2nd diagram mid page if you want to transmit RGB.
Les Wassall HiD50.com leading light in HiD UKGSer Subscriber Joined Jan 15, 2003 Messages 4,038 Reaction score 10 Location Cheshire Dec 20, 2005 #3 Open it up, or buy one from Argos,with gold plated pins and states fully wired and shrouded
boxer Like Newton - only stupid UKGSer Subscriber Joined May 1, 2002 Messages 2,485 Reaction score 223 Location Clinging to reality by a finger tip. Dec 20, 2005 #4 Thanks each
Deleted account 220427002 Registered user Joined Dec 27, 2003 Messages 20,425 Reaction score 4 Dec 21, 2005 #5 don't fall for the gold plated bit... it's not that important.. the cable itself is more important if you can get hold of one of the scarts that come with Sky boxes you'll find them pretty good. some of the so called "good ones" have little or no screening between the cores.... hard to tell a good one from a bad one without plugging it in. but i have seen some bad ones having something priced at £15 or £20 does not guarantee it is good... but it likely isn't bad ( if you know what i mean)
