Schuberth Sr commas collar
paddy
Chichester
Gys
Any help on this one.
My schuberth C3 pro sr Bluetooth radio and Bluetooth seems to have stopped making any sounds, working all the way through Europe 3 rd charge and its all paired etc but no noise from anything. all charged ok.?
Same as scala rider I believe.?
Now moving up France again and missing my music,
Anyone no what's up with it or can it be fixed on the road.?
Many thanks
Paddy
Reset
On your music device is it showing that a connection has been made.
If not you may need to reset the unit and repair all your bluetooth devices to it.
To reset you need to
9.8 RESET PAIRING (RESTORING THE ORIGINAL DEFAULT CONFIGURATION) This section is only relevant once you have completed a pairing process You can delete all of your paired devices at any time as follows:
1. with the SRC‑System™ headset turned ON, press and hold the Mobile Button for at least six seconds until the Red and Blue Lights begin rapidly alternating.
2. Press and hold the Volume Up Button for three seconds.
3. The Red and Blue Lights will flash five times simultaneously and then the headset will turn off, confirming that Reset was successfully completed.
Give this a go and see if that helps.
Update
Quick update. Needed a new src as dealer said it was U/S . New one fitted hope this one lasts longer.?
Paddy
