Screen extension recomendations
Manifold_Burrito
Sussex
Hi folks.
I'm looking for a screen extension or options...after my last trip I noticed a little buffeting unless I crouch just under the screen by an inch.
Any recommendations please?
Here is my current setup. I think it's a standard screen
I tried an extension but got annoyed with it
mra vario screen works really well for me!
I am going for the MRA vario as well. Was going to go for the smoked gray first off but, now thinking of clear if still available.
Jaws Motorcycles in Warrington sell them for £116.
MRA all the way :thumb2 Depending on - if you need only an inch the MRA sport will work. I use the MRA Touring.
Thanks for the info guys..Do tobinators work? Would that give me that extra inch lift?
Sent from my SM-G920F using Tapatalk
I picked up an extra height touring screen off the shelf from Skidmarx in Weymouth for my 1150 it was originally fitted with the standard adventure screen. What a difference pretty sure paid £80 and decent quality as well just measured it from lip above light unit it's 600, 200 more than standard
I use one of these MRA screen extenders which I picked up second hand
http://www.adventurebikeshop.co.uk/mra_screen
Have swapped it between my last few bikes.
+1 I tried all sorts of stuff on mine including torbinators. The MRA xcreen was the best by far.....completely removed the buffeting. I had mine on the lowest setting and was hardly above the top lip of the standard screen....but the difference in airflow was stunning....took a bit of playing around to get it just right but it is easy to adjust. It was so good that I have swapped to successive bikes.
I found that myMRA with adjustable top was very cold in the winter. Great if you do town/short journeys but not motorway. However, we are all different.
I think we are talking stock screen with the MRA xcreen attached. I had 90mph on motorways and no buffeting.....great in winter apart from when it rained as I needed more airflow to clear my visor...adjusting the MRA a couple of clicks usually sorted it.
