Screen Fixing Bush - £40 - ouch!
OldCroc
Welton nr Lincoln, England
Just changed my standard screen for the Givi A330. To my dismay I found that I have lost a bush with a collar for one side. This is the bush that goes through the plastic adjuster assembly (ratchet). I am told that the only way I can get another is to buy the full fixing set for about £40 quid! :blast:blast
Does anyone have some spare fixings lying around - in particular one of these bush/collars? I have also managed to twist off the plastic knob on the adjuster bolt so I am also in the the market for one of these. I am happy to pay any reasonable costs.
Post up some pics of the offending parts.....
Being told you can only get a replacement for XXXX quid is a world away from being able to find something that will do the job as well as, if not better, for a few quid if you don't mind a teeny bodge or two that may well be invisible in the end :thumb2
My thanks to all. I have successfully negotiated a mutual deal with Mikeyboy for some of the bits he has on a shelf in his shed.
OldCroc
