screen needed for s/t what do you reccomend
jackassdave
in a parallel universe far far away
bit of a large title but basically i need a new touring screen for the s/t the one i have does not seem to have any fixings for the the two bars from the screen to the handle bars so seems to slip up and down .
they are not threaded or have locating pins etc ,so i am looking for a med /large style touring screen i have seen some that incorparate a small /slight handguard flare but for the life of me cant remember where i saw it .
so can any one recommend or point me in the right direction where i can view /purchase a screen
The PO of my G/S fitted a Givi A210 which looks similar to the one fitted to your bike , but is smaller and neater and as it is angled correctly will probably give cleaner air than the existing , which looks a bit too vertical.
The A 210 is meant to fit to the headlight bolts, so on the G/S where there are none he had fitted a pair of headlight brackets which worked quite well and gave a bit more adjustment options.
There is another model of 210 which fits back to the bars if you prefer.
Stock GS hand guards fit, and work well with a screen too.
Motorworks used to stock them - dont know if they still do.
