Screen recommendation
borat
Member
Uk
I find with the standard screen the wind still catches the top of my head at highest setting, but not by that much, so I’m looking for a bit of a taller screen that helps, but not too crazy. The Puig ones seem very high. Also prefer to keep the separate deflectors vs a wide screen... Anyone of similar height (6’1) had similar requirements and can you recommend one?
Maybe the GSA higher screen ?
Do you have the screen on the top screw setting?
I find my WRS screen good.
I put the MRA Vario from my 1200gs onto mine, Tramuntana version so has the electric screen, I find it deflects perfectly so I get virtually no noise, no buffeting (6’) from 3/4s to fully extended.
I have the electric screen on the tramantura version so have it on max. It’s useful as can feel the airflow move up, which stops just a little too low. The gsa screen is pricey or i would probably do that one.
That’s a good question I wasn’t even aware there were different settings so will check
Try a screen extender first, cheap (£20 AliExpress), works well for me, used it on 1250gs and now on 1300gs. Don't need to put it up too high just a 3cm or so and it breaks up the airflow and pushes it higher.
