Screen removal
  • Thread starter Thread starter brianski
brianski
Can someone please help with this. How do you go about removing the screen? Is it just a case of undoing the Torx screws and adjusters and then pulling the screen off or is there something else i should be doing. i ask becuase i had a go at this and it didn't budge. i didn't want to use too much force and break the damn thing.
Cheers.
removal
undo the four torxbolts (two each side) and remove them completely then just flex the screen and it will come away one side at a time - it can be quite stuck but is VERY flexible - you won't break it !!
Sherps;)
Easy..
Sherpa, means pull the screen out away from the bike.. there are two lugs at the front that you have to pull clear.. they are the hinge/pivot points.
The two front bolts are very long and the two back ones are shorter.
When you pop em back in, good idea to pop a bit of thread lock on em, and dont be too ham fisted tightening them up.
It is really easy.. i have done it a couple of times to fit the tobinator mounts and an ermax screen.. if i can do it.. it has to be easy..
Thanks guys I'll get to it this afternoon after watching Moto GP
