To give some more info to Doc
The old Hexhead if i recall had a stock seat height of 850mm - 33 inches dropping it to the low position brought it down to 840 odd
With the low seat got it to 820mm 32 inches , with the rear preload on low to none
meant you could almost get the balls of your feet on the deck
Fitting 30mm lower Wilburs took it to 790mm - 31 inches ( bliss) flat foot one or other side with ease, and balls of the foot down on both sides
Move forward to the wethead and we got the low models, a misnomer if ever there was one
the bike is the same size, all the "low" comes from fitting 30mm lower suspension, centre & side stands, and optional low seat if you want it
Great so we start with 790mm and a low seat = flat foot both sides - erm No
The wethead seats are wider, so any gains in "Low" are lost by gains in "Width"
so std height is 850mm 33.4 inches, Low is 820mm 32.2 inches, Extra low suspension is 800 mm 31.4 inches
so why with low suspension & low seat, cant i flatfoot both sides i can do one or the other but not both
Because the Wethead seats are 30mm wider than the Hexhead so your legs are spread wider than before 15mm isn,t much, but x2 is 1.1 inches lost
so you effectively have gone back to 830mm in height .
Going to the Ultralow seat, removes another 30mm in height, i'm not sure about the width i forgot to check that when i put it on
You can see this from the taper too
Hexhead low 310mm rear - 260mm front (50mm) LC low 330mm rear - 270mm front (60mm) TTlc 320mm Rear - 270mm Front (50mm)
Depth of padding HH Low 100mm Lc low 90mm TTUL 60mm
See the pics below
Note the LC low seat has already been modified by me in an attempt to lower it. i took 30mm off the seat area and bout 15mm each side in the taper
