Sena - Mesh 2.0 v 3.0
mw3230
Tyne and Wear
Just in case you didn’t know, SENA (Not sure about other brands) Mesh versions 2.0 and 3.0 are not compatible.
If your intercom has recently been updated either by doing it yourself or automatically then there is a good chance that it will be set to operate on Mesh 3.0 meaning that you will not be able to connect with others if their kit is not updated or set to v2.0. It’s easy to check using the SENA App where you also alter the setting.
Seems daft!
