Service offer
crampie
Barred from Barcelona
Devon knows how....
Please find the following, substantially reduced service prices - for a limited time only.
R1150GS Annual Service: £159.00 inc VAT
This includes:
Fault code memory check
Outstanding recall/campaign check
Changing engine oil
Replacing oil filter
Checking battery acid level
Cleaning and greasing battery terminals
Changing brake fluid, front
Changing brake fluid, rear
Check operation of side stand switch
Check spoke tension
Check lights
Test ride as final inspection and function check
Service wash
R1200GS Annual Service: £129.00 inc VAT
This includes:
Changing engine oil
Visual inspection of hydraulic clutch system
Visual inspection of brake pipes, brake hoses and connections
Check front brake pads and discs for wear
Changing brake fluid, front brakes
Check rear brake pads and disc for wear
Changing brake fluid, rear brakes
checking freedom of movement of Bowden cables and checking for kinks and chafing
Checking tyre tread depth and tyre pressure
Checking ease of movement of side stand and centre stand
Checking lights
Function test, engine start suppression
Final inspection and check of roadworthiness
Setting service due date and service countdown distance
Check battery charge state
Service wash
All prices include labour, genuine BMW parts and Castrol oils and as much coffee as you can drink!
This offer is only available on bikes booked in for service between 13th and 31st December 2012 and is subject to workshop capacity and/or technician availability.
Please contact Bill or Mark for further details or to make a booking - we may even be able to arrange local collection and delivery and we would be pleased to quote - at substantially reduced rates - for any other work you may have in mind (tyres, navigators, paintwork, etc).
Ocean Plymouth
01752 202828
