Bear
Can anyone point me to detailed information about the servo-assisted ABS fitted to my 2006 model GS please. On an occasional basis I lose the servo-assistance to the rear brake (accompanied by the RTOD) but the front brake is still assisted. If it happens it's almost always in heavy traffic with a pillion using only the front brake (I don't use the back brake as I can't easily reach it). My thoughts are that either the servo is drawing so much current that the battery voltage is low (battery is a 3 week old Exide of the same specification as the original) or some sort of sensor in the ABS unit has an intermittent fault. The alternator is working (voltage across the battery rises when engine speed rises) and the fluid levels are correct. The fluid was dealer-changed 1500 miles ago at the last service. The brake light works correctly from both levers even with the RTOD lit up. One interesting oddity is that when I tried starting the bike with the front brake held on the odometer showed 251 miles remaining. Cycling through the display options still worked. The oddity went away after switching the ignition off and on a couple of times. If the problem was always there a dealer should be able to find it but I'm not prepared to let someone take repeated guesses at my expense until the whole bike has been replaced.
