DollyRocket
Yes - another servo query.
I have 2003 1150GS, been playing up recently with a number of faults, biggest annoyance is the abs/servo playing silly buggers, on my 40 mile journey to work / home each day my abs gen light comes on & i get the 4Hz ABS light flash about 4 or 5 times throughout the journey. I generally stop and switch off and on again to reset the system and all is ok for a few more miles.
During the fault, the front brake works ok-ish, (I assume residual), the servo screams away under the tank and the rear brake does bugger all. Is this a common response to a duff servo? or are there are other failure modes?
Bought a servo off this site which I will get Steppers to put in on the next service, but if there are simple other things to check then I'll do that first.
Ta.
Ta.
