ts2
I can't think of a quick way of writing this, but I'll try and keep it short.
My brakes would occasionally squeal when I wasn't pressing/pulling them. The brake light would also stay on (as attested by a following rider). I took it to BMW and they said the hand guards were loose. This surprised me, as I had checked the position and it was OK, and I could also push the lever forwards and it sprung back fine.
Anyhow the problem went away for a bit. Thing is after a nice long ride the problem came back. Lever still moves fine, and hand-guards appear as tight as ever (ie moveable, but it takes some force). Forcing the handguards out of position, then back into position seems to have got rid of the problem, but it got me thinking about what the underlying problem is.
So it doesn't appear to be a crude: handguard pressing on brake lever; or I wouldn't have been able to push the lever forwards.
The lever also sprung back, so it didn't appear that the guard was gripping the lever.
My thoughts now fall to stiction. Could it be that the guard was just far enough out of place that it added friction to the lever's movement? If so, how would this cause the electronics to sense that I'm applying the brakes when I'm not? I was wondering two things, either: a) the brakes stay slightly pressed in after I brake, and so the bike doesn't realised that I'm not holding them; or b) the bike resets the "zero" position each time you put the key in the ignition, and this reset moves the brake on position to a point that is close to no brakes applied?
How does the bike sense when to start the servos? Is it a simple switch, or a pressure sensor?
So in the end I'm wondering if this has happened to anyone else and any tips on how to spot it when you're riding along?
Also I've seen Nemezis's thread on how my servo brakes will kill me if I don't change the guards [sarcasm doesn't work well in text form, but I refuse to use smilies], and I suspect these are related, but can anyone shed some light on the cause of the problem (without saying "BMW are shit, you're all going to die!"). It doesn't seem to be as simple as the guard rotates and presses the lever?
Anyhow I've written to much. Hello to anyone who made it this far in my text.
TobyS
TobyS
