I did this a couple of weeks back, I fitted Ohlins.
I took the back wheel off, the rear was very straightforward, even the bolts came out easily.
The front was more of a challenge. I used a combination of Cookies walk through and Jim Von Badens.
Basically took off generator cover
Put a bottle jack under sump guard and lifted front, but the extra bit I did just to give me slightly more room because the brake line gets too tight, was to remove the support where the brake lines join (beneath the RH Headlamp support - just follow the brake line, it's easy to spot), Once I did this it was simple.
Did it on my own, very straightforward.
