Short rear indicators. Where from?
Taff
South West Wales
I need to change my rear indicators for shorter ones, to get my Touratech panniers to fit. The last time I changed them, I arranged for Rydales to fit a set of Dakar indicators I had lying around, although in fairness they did not recommend them.
So where can I get replacement short indicators from? :nenau
M&P do short mini indicators (mail order service available). Not BMW shaped though if this matters. :thumb
Metal Mule supply an adapter for their panniers that allows you to use the original BM indicators without the spacer. Cost is about a tenner. You would need to check that they would suit whatever pannier system your intending to fit tho'
KRBV
west coast traveller said:
.. Always check bulb wattage rating is the same as origional otherwise indicators can go haywire i.e flash far to fast.
This is a problem I had with the Dakar indicators (and probably why Rydales didn't recommend them) but in the end I just put more powerful bulbs which cured it.
Thank you gents. Right, I'm going to have a go at cutting the existing ones to size and refitting them. If I balls it up - then I'll buy the shorter ones. :thumb
