rustychain Active member UKGSer Subscriber Joined Nov 25, 2022 Messages 199 Reaction score 73 Location York, North Yorkshire Dec 29, 2023 #1 I presume the fairing bracket should be straight and not cockeyed??? The welds are intact which I know can be an issue.
DrFarkoff Grumpy Ole Git!!! UKGSer Subscriber Joined Jun 27, 2006 Messages 14,147 Reaction score 2,146 Location Islandmagee, Co Antrim NI Dec 29, 2023 #2 if your tank and panels line up without stupid gaps or a struggle to fit them? Then it is fine
rustychain Active member UKGSer Subscriber Joined Nov 25, 2022 Messages 199 Reaction score 73 Location York, North Yorkshire Dec 30, 2023 #3 A couple of the fairing fixing holes don't line up, which is why I dismantled things. This will also explain why the lower mounting points are a pig to line up on the front frame. I'll attempt to straighten it a little.
wessie Registered user Joined Jan 8, 2002 Messages 20,193 Reaction score 8,422 Location Welshpool Dec 30, 2023 #4 the BMW part no. is on the item 46632328688 - google it, select Images and you will see pictures
rustychain Active member UKGSer Subscriber Joined Nov 25, 2022 Messages 199 Reaction score 73 Location York, North Yorkshire Dec 30, 2023 #5 wessie said: the BMW part no. is on the item 46632328688 - google it, select Images and you will see pictures Click to expand... Thanks Wessie - I tried that route but the parts diagrams show the bracket from an offset view point. Hard to tell if the 'arm' should be straight. I've just an image with a head on view - it should definitely be straight!
Wrigsby1 Well-known member UKGSer Subscriber Joined Aug 27, 2009 Messages 4,894 Reaction score 768 Location AB51 Dec 30, 2023 #6 That should be straighten-able... I have experience of other brackets...
Lord Snooty Well-known member UKGSer Subscriber Joined Jan 6, 2002 Messages 11,476 Reaction score 2,967 Location Redditch, Worcs Dec 30, 2023 #7 Definitely looks like a bit of a kink in it on the left hand side which poses the question how did it become like that?
rustychain Active member UKGSer Subscriber Joined Nov 25, 2022 Messages 199 Reaction score 73 Location York, North Yorkshire Dec 30, 2023 #8 Wrigsby1 said: That should be straighten-able... I have experience of other brackets... Click to expand... Looks like your were right. A bit of vice work and manual manipulation seems to have done the trick.
rustychain Active member UKGSer Subscriber Joined Nov 25, 2022 Messages 199 Reaction score 73 Location York, North Yorkshire Dec 30, 2023 #9 Lord Snooty said: Definitely looks like a bit of a kink in it on the left hand side which poses the question how did it become like that? Click to expand... A good question. Not happened under my brief ownership. Nothing declared by seller from this forum. A previous off?
Wrigsby1 Well-known member UKGSer Subscriber Joined Aug 27, 2009 Messages 4,894 Reaction score 768 Location AB51 Dec 30, 2023 #10 rustychain said: Looks like your were right. A bit of vice work and manual manipulation seems to have done the trick. View attachment 298515 Click to expand... I once had a CBR6 subframe straightened with the help of a forklift...
