Pauly S
well thats sorted care of jimmy mac. just need to get some thin stainless strip and get busy with the tig.
The eBay lights I am referring to are the one in the link above my previous post. The lights don’t have a definitive pattern, so only really useful as daytime lights.
My set up is the same but not as permeant as Jimmy Mac's, I use some rubber mounted clips to attache Hell DE HiD Spots above the O/E fogs then ballasts onto a bracket under the beak, unable to attach pictures if you pm a email Ill send some over, the DE spots with be for sale soon (theses are the spot light version DE) I have decided to down size.
Good to know as they appear identical to mine which have the same claimed light power and the same actual wattage. I used add-on angel rings which cost under £20 pair complete with plastic cover rings. Clip in the LED ring and seal the back with body panel adhesive/filler.
Mine have an annoying three functions that will go off at random. The fix is on YouTube - basically snip a wire or remove the flashing mode controller chip.
