Side stand foot
batman1
North Lincs
I'm looking for a nice side stand foot pad, the Wunderlich part no. 27380-100 looks like a beautiful bit of kit, but it's getting on towards £38.00 with post.
Has anyone seen anything as good for less dosh.
If not I'll go for it!
I got the Hornig one with the height extender, a little more, but it lifts the bike a fair bit more than the Wunderlich one. Worth it for a short ar** like me.
http://www.motorcycleparts-hornig.c...rade-Steel/Side-stand-foot-enlargement-2.html
SMB
I am thinking the same thing! In my mind it looks the best just seems expensive:nenau
Never bothered with one before so not sure I need it:confused:
Warning: Stupid Question.
Am I right in assuming the main benefit of these things is for use on soft ground?
Does the term ground not cover tarmac?
:nenau
:thumb
I suggest either a pole or a 5 page debate.
You don't think of tarmac when you say soft ground:rolleyes:
I have had trouble before with my side stand sinking into what looked like hard tarmac on a hot day, so would this help:confused:
I have the Touratech one, and can recommend it:thumb:hide:D
Exactly!
Mine was sinking into the tarmac last week, I know it was hot, but I also wanted to park it on the grass verge the other day, but was wary about coming back to a bike laid on it's side.
I have got one of those Oxford stand gizmos which is a bit fiddly and takes up valuable space under the voluminous area under the rear seat.
The thicker foot also lifts the bike a little more vertical which should enable another short arse to pull it up from off the side stand a bit easier when fully loaded with passenger.
I just want something to fit and forget that looks good and always works!
How about one of our Rugged Roads ones...........at under £30 as well :thumb2
Did you have to drill through the side stand to fit that?:eek:
Yes, twice. One at the front where you can see the button head, that's just a clear through hole and from the under side it to the leg for an M5 tapped hole..
I want to make another where there are no visible screws from the top.
