Side stand
Captain jack
The shires
Is a bit floppy over bumps. Am wondering if there is a stronger spring available?
Make sure the pivot bolt is tight. Springs tend not to lose their tension . I had a 650 which is essentially the same bike. I had to re tighten the bolts which fix the stand mounting plate to the frame on two or three occasions, I would definitely check that. From memory there are two bolts.
