Sending someone into a bog with a back tyre that looks like a ribbed condom.
Mark
I kept coming off, not sure what it wasbut probably the full tank didn't help matters nor the choice of semi slick tyres and 5 ton of rear tail bag.
The tyres are coming off when I find some decent supermoto wheels. Could be waiting a while as I'm not paying £400+ for them on eBay.
Discovered radiator damage this morning, just missed the piping but makes me wonder what will happen to the 350mile Safari tank when it arrives. Could be a quick £250 writeoff...
There is a big problem with DRZ aftermarket sump guards - they rebound the noise from the dry sump and it's a massive pita on longer journeys. I found it drowned out the noise from my straight through can!
Andrew
Get a grip on reality!
You have a straight-through can and you're complaining about noise reflected from a sump guard??
If you want a reliable DR-Z that you can can also use off-road, a decent (ie CRD or similar) sump guard is essential. If it's too noisy, put the standard can back on!
Greg
