The Grey One
I have been checking through old threads about clutch failure and come across mention of drive shafts failing and giving the same symptoms.
My 1150 developed what feels like clutch slip, it came on quickly, one day OK the next it "slipped" under load at high revs. Bike has done 33,000 miles. I took it out again and at first it appeared OK but within a few miles it was slipping again.
I have removed the starter to check for oil/fluid on the clutch and today I dismantled the final drive to check for rubber in the housing as mentioned in the posts about drive shaft failures. No sign of anything so does that mean the shaft is OK? Is there any way to check it when I get the thing apart to look at the clutch?
John-very pissed off at the moment-fantastic biking weather here and with the season winding down I could be out there most days!
