You
could transfer everything, all in one go, and pretty easily as well.......(Or uninstal stuff from the old machine first so it's not taken over)
You'd use Norton Ghost or Acronis true image....that would create a mirror image of your 'c' drive and others if you wanted, that you could then put onto the new machine..it would effectivley clone the old PC onto the new one.
(It would also clone all the problems, fragmented files, virii, registry problems etc across though)
You'd need a USB2 hard drive that's as big as your existing disk and the software......other than that it's pretty easy to do.
The files and settings wizard as mentioned above would do exactly as it says on the tin....transfer all your data and settings (email accounts, emails themselves, documents etc) across to the new computer, but you'd still have to install all of the software you use on the new machine......
For this, you'd ned either a USB hard drive that's big enough to take the backup file that's created (and they can be damn big) or a big pile of DVD's and a burner.
It would mean though that you're starting off on a 'clean' install of windows, which is a good thing.
First step with the new machine BTW, before you load ANYTHING else on to it, is check it's not running Norton antivirus....
remove it if it is.
Then d/load and install AVG or one of the other, better av progs.......a search here will turn up some good threads (type in Norton and you'll see why).
Only then should you start installing your other progs
If you have any probs, give me a shout...I'm only in Dartford and have a spare 250gb USB drive etc etc.....quite happy to nip along and hold your hand for a bit.
We can even mess about with the PC as well if you want
