essjay
I'm putting my fuse box just above the air filter and I need to find a switched 12v source near there if I can. I'd rather not run a wire from the lights if I can avoid it.
Any ideas? Is there a switched source into (what looks like) the diagnostic plug above the air filter? If so, which wire?
Also - is it OK to turn on the ignition with the tank removed? It's not going to go arse over tit because the tank electrics are unplugged?
ta...
ta...
