7 up is lemonade.
Greg
Greg
delpel said:yes, yes and I think so![]()
At TDC one set of valves was wobbly so I adjusted them. When i turned the motor by had the other side went all wobbly
The engine was unusually noisey before I swopped the tensioner. Clutching at straws with that one.
All the spaces in my tool box are full so I think I have all my spanners
Greg Masters said:I really don't mean to be patronising here, but i suspect that you are working at the very edge of your knowledge envelope here or beyond it even!
More questions:
- EXACTLY what clearance did you set each of the valves at? (Please state imperial or metric)
- Did you recheck the clearance when you had retightened the locking nut?
- (Did you retighten the locking nut?)
- When you say 'at TDC' - how do you know it was at TDC?
- Which TDC was it at?
- Do you understand the last question?
- No? This could be your problem!
Greg
cookie said:you need to be at TDC when the valves are closed & compression is max.
oooooooh errrrr!rotate the crack until the valve you wish to check is fully open
Greg Masters said:Yes, cookie's on the money here!
You need to ensure that you're checking the clearance when the cam lobe is on the base circle. To abolutely ensure that you are doing this, rotate the crack until the valve you wish to check is fully open. Then rotate the crank by a further 360 degrees. By doing that, the camshaft will rotate 180 degrees ensuring that the opening lobe is furthest away from the cam follower and that the cam follower is neither riding on the opening nor closing ramp. A few degrees of camshaft rotation in either direction won't matter.
Greg
delpel said:So when the valves are closed & compression is max that must be when the rockers are not touching the buckets and you can wiggle them back and forth. Must be my technical descriptions - wiggle and wobble.
delpel said:So how do I get access to the cam followers![]()
Steptoe said:All the rocker/valve gear off -
You mention it went down on one side in the crash -
I've had a couple of bikes i bought with seemingly minor damage , i.e. scufs on the rocker covers, tappety on start up .
And it turned out the head had moved slightly in the impact, and the piston had caught the head .
Don't you love good news![]()
delpel said:If this was the case wouldn't the noise be coming from just one side ie the inflicted side. Also wouldn't the engine self destruct quite quickly when it was running. I have done a couple of 100mph runs and the noise doesn't seem to be getting worse and she's not using oil etc.
Steptoe said:Noise was on one side - but i can't hear your noise, i'm on tinternet![]()
Engines didn't destruct, run fine with just a slight tap .
tap
tao
tap
tap
tap![]()
) but
DrAlf said:If you want to risk it, give Russ a call on 07801493053
Good luck![]()
