Spark plug covers
PeterSX
Essex
Ok, so probably a stupid question, but.......
How do you remove the black plastic plug covers ?
I can find info on removing the older versions that ran from front to back on the cylinder head, but not the newer versions that run from top, round the edge,to the bottom.
I've tried pulling at the top and bottom ends, and there is a few mm of movement, but there seem to be lugs at various places that are keeping it in place. I'm loathed to try using anything to prise it off as the chances are I'de end up scratching the head cover !
PeterO
man up and just pull them off:D
Which end do you pull from ?
PeterO
So what's the trick to doing this, because my fingers aren't strong enough to "just pull them off".....
PeterO
