I've been given a PC and a telly with it to use as a monitor. They are connected with a cable with multi-pin connectors with at a guess ten pins, the connectors are blue plastic and have two long screws at each end to screw them into the jacks. The telly is an LG M2452D and also has Audio coaxial connector sockets, one Red and one White, so I've got myself a lead with plugs to match these sockets at the telly end and at the PC end it has a 3.5mm plug which goes into the sound card.
I can't get the speakers to work.
If I plug in earphones into the 3.5mm (green) socket on the PC I can hear the audio.
What's the probable reason that I can't hear anything via the speakers?
