Speed of steering?
snerkler
Derbyshire
I've just tried out the ESA in 2-up rather than 1-up plus luggage. I'm obviously sat a little higher, and the rear shock doesn't soak the bumps up as well, but what I also seem to have noticed is that the bike seems to turn quicker, as though the steering is more precise. Is this my imagination or is this what you'd expect by increasing the preload, and if so why is this?
if it raises the back relative to the front, the steering will get quicker :nenau
Yes, it's exactly what you'd expect. Jacking up the rear of the bike, decreases the effective rake of the steering head which reduces the trail and hence the caster effect of the front wheel. The wheelbase will also be slightly shorter and this means that for any given angle of lean the radius of the turning circle will be smaller.
I used to run both my '04 & '07 GSes with almost maximum preload on the rear shock to achieve the same effect. ISTR that '08 and later bikes actually have a slightly steeper steering head and shorter wheelbase as standard. I run my current bike on 1+luggage all the time when ridden solo to achieve slightly quicker steering than the base setting.
I totally understood this :confused:
Thanks for the reply, bit over my head I'm afraid but at least I understand the end result :thumb2
But, how can the wheelbase be shorter? Surely the distance between the wheels is fixed, and no amount of fiddling with the suspension will alter this? :confused:
The forks are at an angle, leaning backwards OK?
If the wheel slides up it has also to move to the rear, hence wheelbase reduces.
However, it's the angle of the forks that is the bigger influence as the steeper the angle (the more your arse is in the air) the faster bike will turn.
Choppers vs trails bikes for eg
Google "caster angle" as it's too long to explain here and pictures are worth a thousand words
Happy reading:
http://www.gostar-racing.com/information/motorcycle_suspension_set-up.htm
http://www.calsci.com/motorcycleinfo/Suspension.html
http://www.carbibles.com/suspension_bible_bikes.html
http://www.sportrider.com/suspensio...spension_setup_guide/preload_and_damping.html
