Spoked wheels - valve hole diameter?
Slipperyeel
London
I'm about to purchase a TPMS that has the sensors mounted inside the tyre. But i am being given a choice of valve hole diameter...which i don't know the answer to.
Does anyone know if the valve hole in the ADV wheels is 8.5mm dia.?
Many thanks
Iirc,
8.5mm takes a bolt in type stem as fitted to a r100gs spoke wheel
Later bikes have a larger hole to take a rubber pull in type valve
Thanks Mikey. That's very useful
Mine currently have the rubber pull through valve stems, which I think might make them 11.5mm... Still ok for the sensors because they offer two sizes. I just didn't know which
