Sprocket help
Not open for further replies.
Smythson
UK
Trying to install new front sprocket but the darn thing just won't go on. Last one came off no issues and there was zero play in it.
Do i want to heat or freeze the new one?
S
Freezing the sprocket will only make it tighter. I have never had any problems with removing or fitting sprockets to my f650gs. Have you tried giving the output shaft a really good clean? BTW both times I have fitted new sprockets they were Renthal ones, don't know if that helps. :nenau
Andy.
Andy.
Is it an OEM BMW sprocket?
Should just nicely slide on ... fitted a few to mine over the 103.000 miles never a problem, but always OEM
Likewise - never had problems before and always used Renthal which have been a perfect fit. Output shaft spotless.
This one is an AFAM (they're the only company who make an 18 tooth) which i've seen fitted (on the web at least :rolleyes: )
S
Definitely the right one. In fact it's only the second one i can find that's fitted anywhere (the other being a chap in Germany who posted on ADV with serial number showing). According to supplier only one sold in UK. Left it (and the Rental perfect fit one) with a shop to do some work. It was 0.4 mm out. Perfect now. Let's see whether it makes a difference to economy...sod's law after all this not a jot!
Thank you all for your input,
S
