squeaking clutch
mandon
philippines (working in nigeria)
2003 gs 1150 dual spark abs and integrated brake.....28k+ kms on the odo....
i noticed the problem(?) about two weeks ago....when i press the clutch lever i could hear a faint sort of squeaking noise in the middle of the bike where the clutch is.......i rode for a few kilometers and another disturbing sound occassionally pop up.....i called a bmw mechanic and he said that it was the release bearing....yesterday the bike was dismantled to check the clutch area...the lining is 6.3 mm thick....the push rod end ( the one that is not inside the clutch slave cylinder have a bit or mark...and some scratch mark where in the clutch housing........and i was told that it just need some lubrication....tonight the bike was reassembled, now the clutch engages about 1 to 2 cm when the lever is released (which is not like before), when i test drive it for a few kilometers the noise was gone(its about midnight).....then i test rode it again and the noise reappeared.....by the way the slave cylinder was replaced......can anyone help me with the problem.....i dont have any idea what is causing the noise...........
tnx in advance........
