2004 Rockster clutch bleed
chasbmw
bath UK
Bleeding the clutch on a low mileage Rockster, all looks clean and tidy, slave cylinder looks ok, at the end of the clutch bleeding tube there is an Allen bolt. I need to replace it with a Brembos type bleed nipple, fortunately I have one left over from my airhead days. My question is: did bmw use loctite on the blocking bolt?
No lock-tight on the grub screw.
Dip it in a cup of boiling water and then unscrew it.
